Thread: Side Pipes
Old 12-15-2003, 06:11 AM
BMK's Avatar
BMK BMK is offline
Tried to get pipes to run under the chassis but settled for the easier option of side pipes.
Due to noise levels I built a second set of pipes that have mufflers that are twice the length of the original side pipes.
Side pipes now all muffler.
From 111dB down to 96dB - nearly acceptable.
I also had to run a few half circular baffles inside to reduce noise but re directing the gases.
The end result is a loss of about 40 HP - estimated.
About 5 - 10% - but bearable to drive for an old far#.
However, I find the pipes still a bit loud even at 96dB. Had my son drive past and down the road and they sound great.
Importantly they look great also. So I put up with them, like his stereo.
I started with 4" pipes and ran a 2 1/4 perforated inner pipe. This was lightly wrapped in steel wool.
The exhaust guy did the welding and final fit. Cost was kept low. However the real pain now is I must take them apart to powdercoat/heatcoat them.
I am only talking side pipes here. I had the extractors tunned length built and they were previously coated with the original 111db side pipes.
I guess just experiment. Perhaps someone has specifications that you may be able to replicate?
Bernie
Bernie Knight
Mt. Gambiuer South Australia
Bernie Knight
