Old 12-15-2003, 03:17 PM
RPRICE RPRICE is offline
A friend of mine is the distribution manager for the Federal Mogal place here in Memphis. Get me your engine info and I will see what we can find.
Richard Price
Memphis, TN
from the FM web site.
National Oil Seals
Redi-Sleeves
National® Redi-Sleeves
National Redi-Sleeves from Federal-Mogul are precision stainless steel wear sleeves designed to produce a superior sealing surface on a worn or damaged shaft. Whether the shaft is marred by tracks or grooves, Redi-Sleeves represent a fast, easy and inexpensive repair.
Available for shaft diameters ranging from .560-inch to 8 inches, National Redi-Sleeves combine stainless steel construction with a 0.010-inch wall thickness. This thin but durable design allows the original seal size to be used. Redi-Sleeves are pressed onto the shaft using a removable flange. An installation tool is provided with each sleeve.
Detailed product descriptions and sleeve identification and installation instructions are provided in Federal-Mogul's National Oil Seals Specification Manual No. 415.
For additional information, contact your Federal-Mogul representative.
