Old 12-16-2003, 10:22 AM
cobra de capell cobra de capell is offline
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Originally posted by BT SNAKE
If the Muratic acid scares you then go buy a couple liters of Coke and pour it full strengh onto the grease stain and let it set abit then wash it up with a mop. It doesn't do as good as the acid but it does work.
Hersh
Is this true? What about getting oil off of asphalt or would acid work better or would the asphalt look even worse if either one was used?
