  #23 (permalink)
Old 12-16-2003, 04:08 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Whatever method used using an acid/or Bleach solution make sure you are venting everything--and if you value your ability to continue breathing do your lungs a big favor and wear a proper mask for filtering out the resulting fumes--DO NOT EVER use bleach if you have previously cleaned with any product that has ammonia in it--you'll produce a great chemical weapon called Chloramine gas or straight bleach mixed with water creates Chlorine gas and these gases only rise about 6/7 ft off the ground
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
