Old 12-17-2003, 05:38 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Arrow
Hi,
You need some heat in the oil to lubricate properly.
In general the oil should be slightly warmer than the water temp, it should run 190 to 210 degrees, I wouldn't run it over 230 degrees.Your oil cooler should have a thermostat and bypass in it to let oil by until it warms up to go through the cooler.
Perry.
