Thread: Cam Help
Old 12-19-2003, 10:22 AM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default Cam Help
I am rethinking my choice of cams and am considering going from a solid flat tappet to a hyd roller.
Both Crane and Comp cam have retrofit HR's and cams. The Comp rollers/cam are considerable cheaper than the Crane. Do any of you have good/bad experiences with the comp? Or can shed any light of which would be the best way to go. Has using the "melonized" steel distributor gear with the steel roller cam solved the gear wear problem?
thanks
gn
