Old 12-19-2003, 01:42 PM
Mike_I Mike_I is offline
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Just my O2 but I don't think that you went high enough when you were playing around with the pump nozzles. I just had the same problem as you and ended up going from a 25 to a 37 pump nozzle. Try going up from the 35 that you tried. Also, remember that if you end up going over a 37 you need to install the 50cc Accelerator pump.
Good Luck
