Old 12-19-2003, 04:05 PM
blykins blykins is offline
Default Enlighten Me On Push/Pull Clutch Slaves
Are there any preferences? One better than the other? Is the only difference the orientation? I would assume the push slave cylinder would be positioned in front of the clutch fork and push towards the rear, while the pull would be mounted behind the clutch fork and pull, correct? I've never really got down to the nitty-gritty of hydraulic clutches....if someone would care to explain, I'd be happy to listen.
Currrently, I have a small block with a street/strip 10.5" B&B style pressure plate....a Lakewood Toploader bellhousing that requires a slave cylinder. I was planning on going with a Wilwood pedal assembly, and while I was looking, their own slave cylinder popped up. It's a pull type. Would this work?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
