Old 12-20-2003, 06:27 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Valves-Electric $107.50 or $148.50 depending on which type you choose.
Valve-Manual $7.50
Guage comes with the unit.
(www.cantonracingproducts.com)
Your individual plumbing requirements will dictate what additional piping and connectors you'll need.
Options for getting the oil into the engine - most common in plumbed into the return line from the oil cooler with a T and possibly a one way valve to prevent pre lube from going back to the pump rather than the rest of the system.
Alternative - a T adapter at the oil pressure sending unit that will allow the sump to be plumbed in at that point. To my way of thinking the oil pressure sending unit T might be the best way to go. Will have to wait until I acturally have my hands on the car for a final decision.
DonC
