Old 12-20-2003, 08:48 AM
zimmy's Avatar
zimmy zimmy is offline
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Send a message via AIM to zimmy
Neil and others:
You may have missed my post on this subject, but the work of the led circuit board has already been done. See the link to Lambert engineering. He has a 1"x4" Led strip that is a tail light brake light design that is easily fit into the Lucas rectangular housing we are all familiar with. They are very bright (even in direct sun) and they work great. If your flasher doesn't work, you just need to replace the flasher with a newer electronic flasher. I can give you the number if you need. Worse case, he sells the small device to bring the load up to make the old flashers work.
Let me know if you need more info on the conversion process or the flashers.
Call or check Lambert - you won't be sorry.
