Thread: Shell Rear Axle
Old 12-22-2003, 12:51 AM
maxrpm maxrpm is offline
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
How old is the chassis? Is it a stick car? Why are you narrowing the rear? I have 29x12 inch wide rubber under the back with the stock width rear and offset rims, and there's room for more but not necessary unless you're after the steamroller look. Listen to what HighPlains said plus add a pinion snubber & disconnect the front swaylinks & you're well on you're way to two wheel mayhem!
Let us know how you make out!
"If you're not racin' it, you're wastin' it!"-Me
