Old 12-24-2003, 05:57 AM
Dan Semko's Avatar
Dan Semko Dan Semko is offline
Hoosier Gashole Emeritus
Wink
Jerry,
Not a problem because the psi's remain the same regardless of hose diameter. If the tools feel sluggish, just up the compressor psi output. Think of it similar to tire inflation settings. If you put 35 psi in a 15" tire and similarly put 35 psi in a 26" Kubota tractor tire, then measure it with a gauge, the volume will be different, but the pressure per square inch remains constant.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
