Old 12-25-2003, 08:34 PM
blykins blykins is offline
If it's been ran at all, there's probably not a good way of telling if it has been rebuilt...if it hasn't been ran much, then you can look at the synchronizer blocking rings...they will be a nice solid brass or bronze color...otherwise they'll probably be a dull yellow or oily color. How do the seals look? That would be another indication...Also, pop off the inspection plate and see what the gasket looks like. There will be a difference between a brand new gasket and one that has been there for years and years.
If you have to rebuild it, I'll tell you from experience that it's not an easy thing to do...I just rebuilt my own a couple weeks ago. You will not need any special tools besides a good arbor press and some 7/8" dowel rods. The special tool you're referring to is to drop the countershaft (the bottom shaft in the tranny) to remove the input shaft. All you need is the dowel rod I mentioned...you just cut it to the right length, start knocking it in to push the countershaft out, then when it's out, you just lower the countershaft gear cluster to the bottom of the case...then you can remove the input shaft.
Rebuilding a tranny is not easy...but it's very doable if you have patience, time, and a neat way of labeling things and keeping them in order. Also, you'll need to order a good rebuild kit if you do it....one that comes with EVERYTHING....you'll end up just buying more and more parts if you don't get it the first time. You can contact David Kee...or go to:
www.4speedtoploaders.com
I opted to go with the Road Race plus rebuild kit....to get the beefier SKF main bearings.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
