Acetone is the right thing to use to clean a body prior painting if there is any question at all, followed by washing it down with weak soap and water. New and washed diapers seem to be the best rags I've found for the final wipe down steps, prior to the tack cloth. If your body is raw with mold seams still in it, I would bust the glaze on the body with rough sandpaper and a jitterbug and let it cure in direct sun light for a few days prior to doing any body work on it. Even acetone soaks will not get out deep penitrating fluids in fiberglass bodies, like brake fluid or silicone oils though, and the sun will help dry out and cure your body. Paint dry curing lamps will help here too.
cobrashock
Ron Shockley
