Old 12-26-2003, 10:16 AM
PatBurke PatBurke is offline
Default For Sale:850+ Hp Aluminum Fe
-434 ci / 4.375 bore x 3.600 stroke
-Shelby aluminum block
-Dove raised port aluminum MR heads
-Scat “Ultralight” billet crank
-MGP aluminum rods
-JE 15.8 to 1 pistons
-Cam Motion .900” lift roller cam
-Jesel tie bar lifters
-Smith Bros. tapered pushrods
-T&D rockers
-Danny Bee belt drive
-Manley titanium valves
-10 degree titanium locks & retainers
-PSI springs
-custom Jesel belt drive distributor
-Eschelmans carbon fiber tunnel ram intake
-billet aluminum intake base w/ lifter valley oil scavenge
-2 DaVinci HP 1000 3 circuit, annular booster 4150 carbs
-Magnaflow 4 port regulator
-Peterson 2 stage external oil pump
-Moroso full length aluminum oil pan w/ drag link tube & rear sump
-Moroso sheetmetal valve covers w/ spray bars
-ATI damper
-Moroso 4 vane vacuum pump
-CSI water pump
-ARP fasteners
-1/4” aluminum motor plate
This engine goes 8.90’s @ 150+ in a 3200 lb 10.5 tire full size car. It is one of a kind and has the best of everything. I have $50K into it and will sell it for $29,500 OBO fresh w/ new pistons, valves, springs, rings, and bearings. Interesting partial trades considered. I will also take out cam and compression for a streetable combination if desired. Go to my picture area or www.oceanstateperformance.com and click the “customers” link for more pictures.
Thanks,
Pat Burke
(401) 737-1495
febigdog@aol.com
