Old 12-29-2003, 04:46 PM
Dan Semko's Avatar
Dan Semko Dan Semko is offline
Hoosier Gashole Emeritus
Thomas,
Your formula is indeed correct provided that the fitting is not reduced at the impact wrench. When the fitting diameter is smaller than the production source, the pressure is increased. The demand remains constant but the initial volume changes inversely to the pressure and the length which from 3/8 to 1/2 then back to 3/8ths would be marginal. Using your example, if we take a swizzle straw and a regular straw of equal lengths with the same exit opening (port) and measure the restrictive pressure, it will remain constant in both straws exit end.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
