I got a TL with a Mustang tailhousing (I believe 14"), wide ratio gears, 1 3/8 input, 31 spline output, reverse speedometer gear (so I did not need the adapter). Told him I needed it for a Kirkham 427. Came UPS bolted into a stout returnable shipping container.
P.S. David will also need to know if you are going to use a hydraulic throw out bearing or a clutch fork. I am running a clutch fork and slave cylinder.
Gary
