Old 01-02-2004, 10:40 AM
Behzad Vaqar Behzad Vaqar is offline
Cobra Make, Engine: FFR 1149 302
Default FFR 1149 Great Ride for sale
FFR 1149 Cobra Replica - 8,400 miles
$26,000
Cell Phone: 704-577-4467
Titled in NC as an assembled vehicle – No emissions test necessary Built in 1998
Exterior
Dodge Viper GTS Blue with White Stripes
Ford Motorsport 17 x 9 Cobra R Wheels
BF Goodrich 275/40/17 Comp TA Tires front and rear
Jet Coated black side pipes
Hood Hinge Kit with gas prop shocks
2 speed windshield wipers
Paint by Mike Mack at Tri-State Motor sports
Engine /Drive Train
1993 5.0 Mustang H.O. engine
Edelbrock #6037 Performance aluminum heads
Flaming River Rack steering and shaft 15:1 radius
4 Wheel Disc brakes – Fronts: 1996 Ford Motorsport Cobra 13” with twin piston calipers, and cross-drilled rotors. Rear are 1996
Mustang GT 11.0” with solid rotors
Cockpit adjustable brake proportioning valve
1993 Borg Warner World Class T-5 Transmission
Hurst short throw shifter
Centerforce dual friction clutch/King Cobra pressure plate
McLeod scatter shield bell housing
Oil Cooler
Ford Motorsport Cobra Intake
Ford Motorsport 65mm throttle body
Pro M 75mm mass air sensor
Ford Motorsport 24lb. Injectors
Ford Motorsport 1551ph fuel pump
High performance adjustable fuel regulatory
Ford Motorsport E303 cam
Ford Motorsport “Blue” 1.6 roller rockers
Ford Motorsport “Cobra” logo valve covers
MAC equal length headers
MAC under drive pulleys
MSD 6AL ignition with Blaster 3 coil
FFR tubular control arms
Energy suspension urethane bushings throughout
1996 Mustang 8.8 rear end with Ford Motorsport 3.55:1 gears
Interior
Black vinyl seats
Driver seat track
Wind wings
Sun Visors
Battery cutoff switch
Cockpit mounted fire extinguisher
Trunk mounted remote battery lugs
Tonneau cover
Misc
This car was built by Jeff Mirch, with an emphasis on performance. Upcoming college tuition forces sale. This car has been a blast to own, it will be for the new owner too!
http://www.shutterfly.com/osi.jsp?i=...21b35d0a5a05e6
