Old 01-02-2004, 01:53 PM
DAVID GAGNARD's Avatar
Jim;
Check the front "soft" lines..... Thought I had a caliper sticking on my Mustang,changed it,still "sticking",checked and rechecked everything,untill I took off the soft line from the caliper to the hard line.... Plenty of fluid at the hard line,but little coming thru the soft line,it either partially collasped or had some debris in it and it was less than a year old....
Or possibly the side of the master cylinder that supplies fluid to the front could be partially stopped up..... I would start by bleeding the system at the master cylinder and see what comes out of the front line as compared to the rear line,then work my way down the system.....Hope this helps....
David
DAVID GAGNARD
