Old 01-04-2004, 08:19 AM
jmille jmille is offline
Cobra Make, Engine: SPF 1345, 351W Stroker
Default Just Drill the Head Off
Used this many times on Allen bolts up to 2" in diameter. Select a drill bit just a little larger that the thread size. Use the rounded out allen as a guide. Drill down until the head pops off, remove the plate and use a vice grip to remove the remains of the bolt. Allen bolts are often hard you may need a cobalt drill bit.
Jerry Miller
