Old 01-04-2004, 10:28 AM
Edbo Edbo is offline
Cobra Make, Engine: FFR4067, 393W
I've owned and used an older version of that welder for about 8 years. I also have a TIG machine, but it's just so easy to grab the simple little MIG.
I would recommend the SP-135 Plus over the one you mentioned. The model you refer to has a 4-stage tap switch to change voltage. The 135 Plus has a continuous variable control to change it. The variable control was not offered when I bought mine, but I often wish I had it.
The 135 will do a good job for you on mild steel. You need to practice a lot on scrap before you weld anything important. It helps a lot if you know someone who's a competent welder to help you practice, otherwise you tend to keep making the same mistakes over and over.
Ed
We used to own the government, now the government owns us. Where'd we go wrong?
