Old 01-06-2004, 01:32 PM
DAVID GAGNARD's Avatar
The first thing I do when opening a new gasket set is throw the intake gaskets away after tearing them in two,do not want anyone to have any trouble with them.....
Have always used the blue RVT or RTV whichever it is called,clean the block ridge with some paint thinner on a rag and do the same with the bottom of the intake on both ends,let dry,them put a bead of RVT about the size of a pencil or a little larger along the block ridge,let dry a few minutes till "tacky",then carefully install intake,let dry completely and with a razor blade trim off bead flush with intake and engine,makes for a clean,good looking seal,to this date I have never had on leak or "blow out"....
David
DAVID GAGNARD
