Old 01-06-2004, 02:23 PM
Edley Rondinone Edley Rondinone is offline
Cobra Make, Engine: NAF replica, 351W, about 420 HP
Also, because the 351W uses the same heads as a 289/302, the "Cobra-Powered by Ford" valve covers are used in a lot of Cobras.
I had a '65 mustang coupe with a '73 351 Cleveland with '70 4V heads; previous owner had chopped out the inner shock towers at the A-arms, so I had a frame shop realign the A-arms, then reweld the shock towers to clear the 351C. Spark plug changes took about an hour, mainly by using the "Braille" method. Car ran well: 14.60 @ 97 MPH with a 3.00 open rear end, spinning thru most of first gear. Not blindingly fast, but could beat ALL the stock 5.0 Mustangs and Camaros up until about 1989.
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
