Thread: Front End Drift
Old 01-07-2004, 04:33 PM
PCC's Avatar
PCC PCC is offline
No worries Bernie.
My rad sits exactly 4 inches above floor level.
Chassis, just in front of rear wheel 5 inches and fuel tank 6.5 inches.
Based on the above the front end needs lifting approx 1 inch to level the car out.
I find the floating at any speed, but only under firm acceleration on undulating surfaces.
Before the back end was lifted, had no problems as any grunt seemed to force the whole car down into the tarmac.
Pretty sure that when the front end is lifted equilibrium will be restored and it will be a case of simply playing around with the shocks for fine tuning.
Strange you said getting someone else to drive it as I was thinking on the same lines this morning.
Currently back on to the wire issue tidying up here and there.
Remember guys - spend your dosh on top rate wiring as when a problem arises it takes time and effort to resolve - personal experience.
PCC (Peter Craig)
Keep the sun shining
