Old 01-08-2004, 01:35 PM
DKing DKing is offline
Cobra Make, Engine: Heading the 289FIA route, ERA is the choice du jour
Cal Metal:
Yes, "three". They are lined up perpendicularly to the row of cylinders, and have a "progressive" linkage. I assume this means that the middle one opens first, the the two end ones open as you put your foot into it.
Three would be set up like this > ::: (horns) or ||| (carbs)
(Think in terms of looking down on the top of the engine from the side)
Four would set up like this > :::: (horns) or == (carbs)
I thought the system "looked pretty cool" and the note from XK's says that it is "streetable". Not sure if the cool look would be worth the trouble I suspect the webers would bring.
Doug
"Success discloses faults that failure would have otherwise concealed." J. S. Mill
