Old 01-08-2004, 02:18 PM
Greg Kulp Greg Kulp is offline
Randy,
Here's the setup on my car, which has a heater.
Thermostat Housing:
Large Hose to top of radiator
Small Hose to Heater Core
Water Pump:
Large Hose (bottom) from bottom of radiator
Small Hose (upper fitting) return from Heater Core
Small Hose (lower fitting) to bottom of Harrison Tank
Harrison Tank:
Bottom Hose to water pump (lower small fitting)
Top Hose (on tank body) to top of radiator
Pressure Relief Hose (on filler neck) to puke tank or atmosphere
Radiator:
Top Large Hose from Thermostat Housing
Top Small Hose from Harrison Tank
Bottom Large Hose to bottom of Water Pump
Heater Core:
Supply from Thermostat Housing
Return to Water Pump (upper small fitting)
Hope that helps.
Greg
America. Home of the free, because of the brave.
