Thanks for the
detailed information! The only thing I don't know is if my radiator has the extra fitting on the right side for the Harrison Tank. I could see yours in the pictures you posted but I have a piece of aluminum ( trim only ) that I may have to move just to be able to see it. Is this typical in most radiators possibly just capped or will I have to tap in a line?
***UPDATE***Part of my confusion is the radiator is reversed from you guys due to our manuf. wanting it this way. My top is on the right yours is on the left. I found a insert, just on the other side! So I am set! I found a Unique that is the same setup!
Going to do some mods this Winter.
1. New 4 port headers/sidepipes ( ceramic coated )
2. New induction system thru Quality Roadsters ( pending completion of the system )
3. Installation of the Harrison Tank
Oh, where did you buy the vinyl/rubber straps under the alum. ones?
Thanks, Randy
