Old 01-09-2004, 02:31 PM
John 550 John 550 is offline
Cobra Make, Engine: ERA / nascar side oiler
I put a 427 in my car this year . When I was looking and asking questions on the
aluminum at the time , I found there was some machine work , and other things that
needed to be made right in order to start the job right . There may have been changes
since .
I had the same budgit ,
The reason I responded is to tell you :
You don't need to stroke it , unless you need to use the crank !
You dont need to roll the cam or make it solid !
Don't bore it , It's big enough , I think it will run cooler too !
Don't learn how to drive it with other cars , people around ,
you will be amazed how fast the back will pass you !
