Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 07-19-2010, 07:58 PM
Default 460 Alternator
I am rebuilding a Classic Roadster Shelby Cobra AC kit car from the mid 90's. The car was only ran for 75 miles then damaged and stored away. I am going through it from bumper to bumper. It has a built up 460 that the block came out of a 70 Lincoln. The alternator is shot and I noticed it was a old style with the regulator on the fire wall. Should I replace it with the same or is there a better one that is a direct bolt up and has an internal regulator that is a simpler install? I appreciate any info.
Old 07-19-2010, 08:50 PM
PANAVIA's Avatar
There are much better units out there. -- I personally like the 1996 460 Gen III alt. - with the 95A case. (129MM case) -- go see someone at an alternator shop, they can build you a good unit. --
Old 07-20-2010, 05:19 AM
Tom Wells's Avatar
HP,
Can't find an exact replacement with a quick search. Maybe one of these will help point you in a good direction:
http://www.allfordmustangs.com/Detailed/72.shtml
or
http://www.bcbroncos.com/3ginstall.pdf
Tom
Old 07-20-2010, 05:25 AM
PurpleVenom's Avatar
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
What look are you going for, classic or modern? Mine is built in, but it's a chrome cased unit.
