08-22-2010, 04:48 PM
Cobra Make, Engine: Midstates Cobra, RFGT40
Guys, I don't get why these are so hard to find. I thought they were put into trucks, Thunderbirds and a lot of other Ford products.
I ran 1970-71 0n Craig's list and got some hits. One was a 1972 T-bird for 250 bucks. There was a Galaxie 500. and a Merc with a 460 also. If you can get thes cars for a few hundred wouldn't that be a good way to go if you want a torque monster?
Hersh
08-22-2010, 05:13 PM
Ca.
i would rather not drag home a whole car if i dont have to.....but a free 460 OOOHHH YYEEAAHH
08-23-2010, 05:58 AM
It's telling you something....
Originally Posted by 133bus
..... and there was a snake skin under the valve pan cover(true).
Steve
^ I think your answer is right there....this engine is destined for a Cobra..LOL.
- Allen.
08-23-2010, 06:43 AM
AL
I have a Performance Automotive Warehouse catalog (2005) that list a rebuild kits for 429 - 460 from $851 to $1048.
kit includes: crank, rods, pistons, rings, bearings, cam, lifters, oil pump, timing chain and gear.
I have heard that the 429/460 is the cheapest Ford motor to rebuild.
Now I would not want a lot of the parts in the kit, but you could build a mild motor with a butt load of torque for a very little money.
At one horse per cubic, you would have 460 hp.
600 hp from a 460 would be easy.
Great motor.
Dwight
08-23-2010, 07:31 AM
Me
A stroker crank kit,set of aluminum heads,intake and water pump,a decent fuel mixer,top it off with a good ignition and you have a fine air pump to move you down the highway smartly.Make sure whatever you decide on for compression your cam choice optimizes it.
08-23-2010, 07:35 AM
KY
I'm running a special on Scat/Probe stroker kits right....this would be a good candidate for one. They're all the same price....so go big...  552/557 cubes is easy. I'm building one right now for my own personal Mustang.
08-23-2010, 07:51 AM
UK
Cobra Make, Engine: Dreaming of a 427 Competition car...
...there was a snake skin under the valve pan cover...
Probably a CobraJet, then.  Sorry.
Paul
1966 Singer Chamois (Hillman Imp) - full race 930cc
1975 Triumph Stag - 3.0-litre
2003 Vauxhall Vectra GSi 3.2 V6
08-23-2010, 11:06 AM
Member of the north
Cobra Make, Engine: A Cobra
Brent, when did you get a Mustang?
What happened to the vette?
08-23-2010, 12:49 PM
KY
Dave, you ask me the same question everytime we talk.
I haven't had the Corvette in 3 years....
08-23-2010, 12:52 PM
Cobra Make, Engine: dd cobra,351w mild cam
Just finished removing the head on the driver side and as I suspected the news isn't good...there are windows in #7 and #8 cylinders...soooo I guess this is the end of this thread...I'm a little disappointed but like I said all I have in it is some gas money and an afternoon of wrenching...which is entertainment to me.Thanks for all your comments.I'm always scrounging around so if I find anything else I'll let you know.
PS: If I can figure out how to put pics on here I'll post some...including the snakeskin.
Steve
08-23-2010, 01:02 PM
Ca.
Steve......thats to bad.......better luck next time..
08-24-2010, 04:19 AM
KY
bus...
Post pictures. Any way that you can sleeve the cylinders? Or are you just going to look for another block?
08-24-2010, 06:13 AM
Brent,I'm going to see if I can put some pics up today(not real good at that stuff)...as for the motor,it's not a CJ or SCJ just a plane Jane 429,so I imagine the cost could get out of hand real quick...I allready have a 351W with a mild cam and 1968 closed chambered heads in my build...I just thought that with a little luck it would be fun to work at this 429 for the future...what dose sleaving a cylinder cost?
Steve
08-24-2010, 06:16 AM
MI
Not worth sleeving a plain jane 429/460 unless you've got a fully machined piece that you are repairing. Around here a sleeve installation runs around a hundred bucks per hole
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
08-24-2010, 06:27 AM
KY
I've been having trouble finding good 429/460 cores around here. When I do find them, the sellers either want $150-200 for a bare block, or more for a rebuildable core.
It's just a matter of what's available to you and how affordable the machine work is.
Finding a free block is certainly a step ahead....
08-24-2010, 08:22 AM
I was all excited when I say the block ID..D1VE 6015 AA which is suspost to be a CJ block...but after doing some research and found that alot of plane Janes also had the same marking by a factory mistake..I took a closer look and found that this block has the narrow webbing instead of the wider webbing on the CJ blocks...even so it wouldn't cost any thing to make a couple of phone calls.
Steve
08-24-2010, 08:27 AM
KY
Remember that a 460 block isn't your typical Ford block. If you're aiming for anywhere under 800hp or so, this block (or any other) would be perfectly fine.
08-25-2010, 05:40 AM
Me
I have a spare 460 motor, have thought about a big stroker.Why I hesitate is how easy this 460 slides in a turn with a tad too much wick.Can only imagine what whacking the loud pedal must feel like with 100 more cubes.What kind of numbers with say a 557"?Maybe somebody would want my motor.
08-25-2010, 05:45 AM
KY
Depending on the heads and cam....anywhere from 675-800hp. It's easy to get power out of them. A set of P51 heads and a mildish solid roller will get you 725-750 pretty easily without revving the engine high.
08-25-2010, 07:37 PM
Ca.
Steve i just had a sleeve put in a 390 for my kids car and it was an extra 75 bucks for the sleeve and to install it......so on a free motor you may just come out about even if you would have given a couple of hundred for it.....maybe you may want to rethink your decision to junk it.........
