Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree1Likes
Old 10-23-2014, 04:02 AM
mdross1's Avatar
Was hoping to not take the heads off they are the aluminum Cobrajet Racing M-6049-A429, 2.20 in - 1.76 ex - 72cc, port matched to Edelbrock Performer RPM.
Old 10-23-2014, 04:04 AM
My bad, I thought you mentioned in another post that you were thinking of doing some port work...
If you're happy with the cam you have now, switching to a hydraulic roller will be a cake walk....
Old 10-24-2014, 07:18 AM
mdross1's Avatar
I want to polish the intake and water pump maybe even the valve covers (those can wait till engine is back together) I will give Comp Cams a call and pick some brains there.
Been thinking for a long time about a solid roller again will talk to the cam people.
Old 10-25-2014, 05:53 AM
mdross1's Avatar
Comp cams suggestion with how the car is set up was near the same lift but duration increase.
Current cam flat tappet .235 @.050 .560 lift both sides
Comp Cams Suggestion .242 .248 @.050, I - .553 E - .572
Old 10-25-2014, 06:13 AM
I would ask the guy on the other end of the phone how many BBF's he has built. It's easy for the "tech guys" to look in their catalog and read the descriptions, but they may not be familiar with that particular engine's pros/cons.
As an engine builder, I'd be happy to make a recommendation....I build a lot of big block Fords.
cycleguy55 likes this.
Old 10-28-2014, 05:25 AM
mdross1's Avatar
I'm all ears and do hear you when it comes to dealing with the "tech guys" thank you for wanting to suggest a cam.
Mike Ross
Old 11-16-2014, 06:15 PM
lon lon is offline
Default 460 .40 over
just need to know what a stock 460 .40 over displaces and how much horsepower and torque I might get with a 625 carter afb.
Old 04-10-2015, 04:53 PM
Cobra Make, Engine: AC cobra, BB Ford
Default 429 D1VE Motor in my cobra
Runs great
Old 04-24-2015, 11:59 PM
Gaz64's Avatar
468.3 cubes, but you'll run out of breath with a 625 afb.
Would be a good street combo, topping out at about 5000 rpm, would be better off with a 750-850 carb.
