Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-21-2014, 06:04 PM
mnm99's Avatar
Default 429 block ID
This is the number I was given--- 8a8W--- Does it make sense? I was told it came out of a 68 Thunderbird
Old 04-21-2014, 06:48 PM
Tom Wells's Avatar
mnm99,
I don't recognize the number. If it did come in a '68 it might have had a power steering pump on the nose of the crankshaft as did many of the '69 models.
You may need to publish some photos, or better have someone who knows the blocks lay eyeballs on it with you.
Tom
Old 04-21-2014, 07:46 PM
FWB's Avatar
FWB FWB is offline
Agree with Tom, it could be a date code that was written wrong.
68 was the first year for the 385 series but my knowledge stops at the lincolns.
in 68 the 460 in the lincoln (optional) did have a crank mounted ps pump.
so i suppose the t-bird would have been similar.
pics and a better read on the casting date
a little birdie in my head is telling me there weren't any 429's in 68, only the 460, could this be a 428 your looking at
Fred B
Old 07-25-2015, 06:22 AM
Cobra Make, Engine: Contemporary Classics, red white stripes
Default Yes in 68
We had a 68 T-Bird when I was in high school that had a 429.
The engine was original, and I am positive it was a 429. We rebuilt it, or actually replaced it with a 429 from a 69 T-Bird.
I think the 460 came later. A friend that lived a few doors down had a Lincoln Continental with a 460. I don't recall the year model of his car, but I'm guessing 1970.
Old 07-25-2015, 10:50 AM
Bernica's Avatar
Senior CC Premier Member
My reference materials show the following for casting numbers:
C8VE = 1968 429 and 460, all applications
C9VE = 1969 429 and 460, all applications
Old 07-25-2015, 12:18 PM
cycleguy55's Avatar
Here's how to read Ford part numbers: How to Decipher FoMoCo Part Numbers - Overview - FORDification.com
It is my understanding both engines rolled out in 1968, with the 429 in Thunderbirds and 460 in Lincolns.
https://en.wikipedia.org/wiki/Ford_385_engine
Brian
Old 07-27-2015, 10:26 PM
Paul Kane's Avatar
The cylinder block's engineering revision is on the outside of the engine block, behind the starter motor, and reads vertically. For a 1968 429 or 460, the block's engineer revision should be either C8VE-A or C8VE-F.
The actual casting date of the cylinder block is in the the lifter valley and is alphanumeric, such as "8B27" (which would indicate a casting date of February 27, 1968), or "8A8" (which would indicate a casting date of January 8, 1968).
The casting date in the lifter valley is really just a curiosity, and frankly 429/460 blocks regardless of engineering revision will sustain more power and abuse than most people would every consider imposing upon them.
http://www.highflowdynamics.com
Old 07-27-2015, 10:29 PM
Paul Kane's Avatar
Originally Posted by Tom Wells View Post
mnm99,
...If it did come in a '68 it might have had a power steering pump on the nose of the crankshaft as did many of the '69 models.
Tom
The crank-driven power steering pump was on 460 engines in Continentals only, from 1968-1970. All 429 powered Thunderbirds had the standard front accessory drives.
Old 07-27-2015, 10:32 PM
Paul Kane's Avatar
In addition to the above and for a brief overview of the different 385 Series passenger car blocks, click here:
http://www.highflowdynamics.net
