| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
4Likes
12-16-2016, 03:03 PM
SK
Ford Racing Introduces a 572-inch Super Interceptor Crate Engine
The marketing indicates that Ford is after the street big-block cruiser crowd with a pump-gas compression ratio, a moderate 655hp, and a street-fun 710 lb-ft at 4,500 rpm. The package is based on the A460 block with an attractive 4.500 bore and 4.500 stroke. Inside is a Scat crank and forged steel H-beam connecting rods and Diamond pistons. Rotator aside, most of the parts are from Ford Racing including the Super Cobra Jet heads that alone make the engine worth bragging about.
Here are some specs:- Engine Type: 385 Series Big Block
- Displacement: 572
- Bore x stroke: 4.500 x 4.500
- Block: A460 (M-6010-A460)
- Camshaft: Hydraulic roller, 0.649 lift; 259/263 duration at 0.050 lift
- Heads: Super Cobra Jet; 2.20/1.76 int/exh valves
- Compression ratio: 10.0:1
- Intake: Edelbrock Victor 2966
- Carburetor: Holley 870-cfm Street Avenger
More: Ford Racing Introduces a 572-inch Super Interceptor Crate Engine - Hot Rod Network
No word yet on price or availability.
Brian
12-16-2016, 03:48 PM
CA
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Sweet
12-16-2016, 04:05 PM
SK
I like the phrase "a moderate 655hp, and a street-fun 710 lb-ft"!
Brian
12-16-2016, 09:38 PM
AZ
I would rather have Blykins or Craft or Kaasee build one. 722ftpds would be awesome in an old Thunderbird boat size.
PRIDEnJOY
12-16-2016, 11:47 PM
Fl
Cobra Make, Engine: Everett Morrison/Side Oiler
Agreed:Or a tractor pull!
12-17-2016, 04:18 AM
KY
All of that and they put the junkiest carburetor known to man on top?
12-17-2016, 07:58 AM
AZ
"All of that and they put the junkiest carburetor known to man on top? "
Well, it is a Ford, after all.
Karlos
12-17-2016, 08:23 AM
MD
I would rather have Blykins build me one.
www.partskeeper.com
12-17-2016, 08:38 AM
KY
Good point. I guess it only really needs a 2-bbl to make more power than a Chevy. No use in over-doing it.
12-17-2016, 09:07 AM
Oh
I'm a tad bit surprised they need that much cam to get those heads to feed the big inch displacement. Perhaps the heads just are not up to the huge displacement. I doubt they will spin that monster rotating assembly as fast as the cam is capable of going. However I have no experience with such monster engines, so maybe I'm looking at it all wrong.
12-17-2016, 09:12 AM
KY
A 572 needs a lot of cam, relatively speaking. That's a huge engine.
With that being said, the Cobra Jet head is really behind on technology and they are not big performers.
Last BBF I did used Kaase heads, was "only" 529 cubes and made 740 hp @ 6000, with 700 lb-ft of torque.
This engine is still 35 hp above the 572 GMPP engine though, even with using that pathetic little carburetor.
12-17-2016, 08:32 PM
AZ
Thought I might get a rise. Just rousin' da rabble.
Karlos
12-18-2016, 03:54 AM
KY
Nothing wrong with a little friendly ribbin'......
12-18-2016, 07:53 AM
Cobra Make, Engine: All original, with Chevy engine since 1964
Well, in that case....:
My math says that at 100% VE, this 572ci engine should be able to pump the carb's maximum 870 CFM of air at about 5250RPM...
Perhaps Ford is concerned about the bottom end scattering all over the road, if the revs go any higher than that...???
I mean, doesn't FORD stand for:
Found
One
Rod
Danging....?
or wait, maybe it was:
Found
Our
Rockers
Damaged
I guess they're just trying to protect the engine from premature:
Failure
On the
Racing
Dyno
- Robert
12-18-2016, 01:31 PM
AZ
In our area:
Flipped
Over
Reservation
Decoration
Karlos
12-18-2016, 04:02 PM
KY
Cheapest
Heap
Ever
Visioned
Yet
Cheap
Hot-running
Engines
Very
Rusted
Out
Lose
Every
Time
Cheap
Hardly
Efficient
Valves
Rattle
Oil
Leaks
Every
Time
Constantly
Having
Every
Vehicle
Recalled
Over
Lousy
Engineering
Techniques
How do you double the value of a Chevy engine? Put oil in it.
General
Mistake
Government
Motors
12-18-2016, 07:50 PM
AZ
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Cheapest
Heap
Ever
Visioned
Yet
Cheap
Hot-running
Engines
Very
Rusted
Out
Lose
Every
Time
Cheap
Hardly
Efficient
Valves
Rattle
Oil
Leaks
Every
Time
Constantly
Having
Every
Vehicle
Recalled
Over
Lousy
Engineering
Techniques
General
Mistake
Government
Motors
12-19-2016, 07:19 AM
Cheap
Hardly
Efficient
Valves
Rattle
Oil
Leaks
Every
Time
Ok, THAT one is funny
Let's see, how many more can I remember.... (I haven't done any of this Saturday cruise-night trash-talking for about 30 years, haha)
Found
On
Road
Dead
Failure
On
Race
Day
Fix
Or
Repair
Daily
F-ed
Over
Reworked
Dodge
Fresh
Oil
Recommended
Daily
Fix
Our
Recalls
Detroit
Fake
Our
Racing
Data
Found
Our
Racecar
Dead
Of course, none of the above are anywhere NEAR as accurate as:
Mainly
Old
Parts
And
Rust
- Robert
12-19-2016, 12:26 PM
Stolen Avitar
GA
All joking aside, now we need "572 Super Interceptor" fender badges. Oh yes!
12-20-2016, 05:06 AM
FL
Steve,
I'll take two sets of those badges
Tom
