Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree1Likes
  • 1 Post By RRahmer
Old 03-26-2021, 07:08 PM
kitcarbp's Avatar
Default 460 Stack Injection
So I dont know how you all feel about stack injection on our 460’s but when I saw the execution on this 460 with stack injection system, I was smitten. If I remember right this motor was stroked too. Its now a personal goal some day for my Cobra. Its a lot of money for the “bling”, but man it looks good
This was in a 66 Fairlane from PA at Endless Summer cruising in OC MD last Oct. well done I thought. I’ d like to hear more from personal experience with these units on 429/460? Here is the Speedmaster kit. You need to add injectors and the sensor kit to this.
https://speedmaster79.com/Ford-BB-46...System-Black_2
Old 03-27-2021, 08:56 PM
PurpleVenom's Avatar
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
Interested to see how this could be done on the 460
Old 03-28-2021, 03:50 PM
cycleguy55's Avatar
Check out this thread: Speedmaster '8 Stack' Down Draft EFI System
Brian
Old 03-28-2021, 07:32 PM
Specialty Vehicle Builders
https://specialtyvehiclebuilders.com...rnal-fuel-pump
Old 10-23-2024, 12:31 PM
Registered User
Hi, that’s my Fairlane in the picture. It is a 532 Cubic inch based on a 460 (385 series) Ford (Dart 4 bolt) block.
The injection manifold is Speedmaster as someone pointed out, however, the EFI set up is by FAST.
I would also add, the intake manifold required a noteworthy amount of modification to actually work correctly. The fuel rails and other parts did not fit as well as advertised. Machining was required.
Furthermore, I will tell you if you’re thinking about this… The cost of the manifold is only the tip of the iceberg. You’d better be prepared to spend $10,000 on this set up. Intake, manifold, injectors, EFI, computer, set up and tune.
Finally I’d also like to point out at the average tuner is not qualified to work with dialing in eight stack injections. He requires special tools to balance each cylinder Correctly. This was true of the mechanical versions even before they were EFI.
I have a great tuner. I’m happy to recommend to anyone looking to build this set up, But I want to be transparent about how simply can seem versus the reality of really installing this sort of eight stack injection on your build.
If you have questions, feel free to reach out happy to answer.
- Rus
SanDogDewey likes this.
