Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 06-01-2002, 03:02 PM
Send a message via AIM to kiln
Default good buy or not??
I found a 429 SCJ 4bolt main complete engine (without dist and carb) for 2800... how does that sound? to much? good price? or should i keep lookn .. its STD bore and STD crank
ryan
Old 06-03-2002, 01:20 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Bear in mind, a 429 is a different crank/cam/head 460, unless you are getting a set a rare number heads, it seems a little high to me.
Grumpy
Old 06-03-2002, 01:58 PM
Wat about the SCJ 4bolt main block for 1400?? still to high?? lemme know
Old 06-03-2002, 02:27 PM
bran3b's Avatar
Cobra Make, Engine: Midstates, 460
I have a 429 block and heads with a 460 crank that works great, but it is heavy. What condition is the engine in? You can expect to pay at least $3000 for a basic rebuild, more if you need new pistons/rods...
$2800 for a strong engine sounds like a good price, high for a tired engine.
The other advantage with a 429 is that they stopped building them early ('72 I think) which could help with registration/emission problems.
I don't know about the SCJ, but a basic 429 is the same block as a 460.
Don't know about the block alone.
"Clowns to the left of me,
Jokers to the right..."
Brandon
Old 06-11-2002, 03:50 AM
Hi all, new here. I have a 429 Ford that was in a late 70s truck. How can a guy tell what it is and where it is from. What is a basic good running engine worth? I am a Chevy guy and this is my first Ford. Thanks, James.
Old 06-12-2002, 07:03 AM
Kiln - Why fool with the high dollar stuff when junkyard blocks work just as well? A 460/429 of any vintage will accomindate 6 or 7 hundred horsepower if done right and your not risking tearing up a high dollar block. Save that block for a muscle car resoration and don't use it on a Cobra IMHO. If you are skidish about using a stock block there is always main girdles and stud kits (cheap) out there. Also remember that the 4 bolt main block weighs more than a stock block in most (not all) cases. My aluminum headed stock blocked 544 cubed engine weighs in at 540 Lbs. minus the supercharger for example. I know the 4 bolt main block is at least 25 lbs heavier. That don't sound like a lot but on a Cobra every bit counts bigtime in the front of the car. To back up my claims just look at the crate engines Ford is selling. No trick stuff there on the bottom end. Just solid hotrod parts. As for costs, the last time I looked a year ago a 460 SVT iron 4 bolt block cost about 1700$. This is a block that is heavy by 460 standards but can be bored to 4.5 inches or better and indeed is stronger in MANY other respects. Those prices are TOO HIGH for the scarce stock blocks IMHO, though I know that's the going rates.
Chavez64-Welcome to the CC board. Hope your Ford experiences are good ones.( I know they will be) You might try expanding your search to 460/429 stuff to give you some insights to this engine family. As for costs, a lot of that is subjective and this is also affected by your local. Internet pricing tends to be on the high side for some of the scarce stuff and in almost all cases this is unnecessary anyway.
Cobrashock
Ron Shockley
