Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 02-21-2003, 06:49 PM
jdean's Avatar
Default Mobil One oil in a C6?
I'll post it here, since 385 series is where a lot of the C6s are attached.
Over in the 385 Engine forum, I have read where someone that has a BBF competitive monster truck (Big Dawg) uses only Mobil One 5w-20 synthetic oil in his C6 instead of tranny fluid.
It is almost a stock C6, in a very abusive situation and they have no problems with it.
Has anyone ever heard of this? I wonder why this idea has not caught on?
Old 02-21-2003, 07:05 PM
wizard's Avatar
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
I have a C6 bolted to a 460. Running Mobil synthetic in the BB (4000 miles) but question the wisdom of motor oil in the tranny.
Having said that, leave it to a good Red Neck (term of endearment) to teach the engineers a thing or two.
The Wiz
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
Old 02-23-2003, 07:14 PM
Naja's Avatar
Just had my tranny fluid changed out over the last week.
It may depend upon what type of material that some of the parts are made from. My C6 was built using Kevlar bands, other, premium parts, a shift kit and Dexron was put in it. I complained of mushy shifts, but their adjustments didn't help much.
A couple of weeks ago the shop had one of their transmissions from a Camaro that was drag raced quite a bit come in. The owner of the car called the manufacturer of the converter to ask why he was having so much trouble with the transmission since it had to be rebuilt a couple of times. After describing the other parts used in the tranny (similar to mine), the first question that the manufacturer asked was, "What kind of fluid are you using in the tranny?" The Camaro owner was using Mobil One. The manufacturer said, "WRONG!" With the parts being used, you must use Type F fluid - NO SYNTHETIC!" They replaced the parts that were damaged, then put Type F in his tranny. They said it made a world of difference.
Because of the structure of my tranny, they could only change out around 50% of the fluid, but they did this 3 times over a week, so I have about 90% Type F, now. I has made a noticeable difference in the firmness of the shifts.
I have a tranny fluid temp gauge. The Type F runs 10-20 degrees cooler than the Dexron, which makes sense because there is less slippage, and , hence, less heat generated.
Old 02-23-2003, 07:43 PM
Cobra Make, Engine: CSX4000, 427
Mobil makes a synthetic tranny fluid, marketed as Mobil 1 ATF, compatable with Dextron III. I use it in my suburban, thinking that it will hold up better to the heat generated with towing, compared to regualar ATF.
Was he using Mobil 1 ATF in his C6, or Mobil 1 motor oil?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 02-24-2003, 11:16 AM
jdean's Avatar
He was using Mobil One motor oil, not synthetic tranny fluid.
6th generation Texan....
