Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-12-2004, 05:23 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Bellhousing for a 460ci (truck engine)
Looking for a bellhousing for a 460ci truck engine big block.
Would this be the same as a normal 460ci bellhousing, or is it different due to it being a truck engine?
Are there spacers or anything like that involved in fitting it in place?
Also, any ideas where to find a clutch package for this setup?
Looking to hook it up to a T-5 if at all possible.
Anyone . . . .
I'm not busy because I did it right the third time . . .I think!
Old 07-12-2004, 10:36 PM
jdean's Avatar
Truck engines have nothing different compared to car engines as far as bellhousing bolt pattern, fit etc. All should be interchangeable with the blocks.
You might check on an aftermarket bellhousing from Lakewood or McLeod for the T-5. Hope you don't plan to drag race with that T-5 behind a stout 460 though.
6th generation Texan....
Old 07-13-2004, 09:04 PM
I have cast iron bel hsg w/ clutch fork and t/o, flywheel, used (lo miles,) HD clutch and presure plate
350.00 plus shipping
reply w/ email or phone if interested
