Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 09-07-2004, 03:41 PM
Cobra Make, Engine: 460
Default lifters
On a stock 1969 460,78,000 miles, 10.5-1 comp. ratio, can i change the lifters and leave the old cam? some people say yes,some say yes. which is it? Thank You, Dennis
Old 09-07-2004, 04:56 PM
Cobra Make, Engine: Shell Valley 302
NO. New lifters have a convex bottom with an approx. radius of 36". This can be seen by placing two new lifter bottoms together. With this many miles your lifter bottoms are probably flat or concave. Also note that your cam lobe has a slight taper to it. This plus the radius on your lifter enables it to spin. Your old cam will not enable your new lifters to spin, causing you much grief. Have a pro change cam, lifters and timing set as it's tired also. No need to change cam bearings as they are one of the lightest loaded components of your engine, as long as they are not damaged by removal or installation. Good luck
Old 09-07-2004, 06:27 PM
I say no! Flat tappets and cams go together as the surfaces wear in together.
Now ROLLER lifters, then YEAH, swap them around just about any way you want.
Old 09-07-2004, 09:02 PM
But you need a roller type cam to install roller lifters, correct?
Old 09-07-2004, 09:08 PM
Assolutely!!!
Old 09-08-2004, 04:29 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Ernie is an expert!
