Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 03-26-2005, 03:37 AM
Cobra Make, Engine: Everett-Morrison 514ci, 5sp Tremec
Default 514 Oil Leak Problem
My 514 had been leakless for a long time but has recently sprouted various leaks. As I plug one up another shows up. This seemed to start after the intake manifold gasket (which was a mess) was replaced. It seems as though there is too much pressure building up in the case but I'm not quite sure what to do (or if this is the real problem). At this time I also changed from Royal Purple Synthetic to mineral based Quaker State Racing 5W30. I have a dual oil filter set-up and 9 quart pan.
Any suggestions would be welcome!!
Regards,
Josh
jjtarnow
Old 03-26-2005, 07:52 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
How is the crankcase vent system?? Needs to breath or blow by pressure will give you all kinds of leaks.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 06-13-2005, 11:02 PM
Cobra Make, Engine: 66,clasic 351w,what a dog,needs boss 42
Send a message via AIM to wboss429 Send a message via Yahoo to wboss429
could have a leakey head gasket,under intake,this is most liky the problem, it goes, pushes out intake,then when its resealed ,it pushes out next weak link,wont leak water,just compression into the under intake,did u detanate it latly,(ping)
c9ae-zx
Old 04-08-2006, 08:01 AM
craigayl's Avatar
Cobra Make, Engine: Superformance Cobra SC, 514CID
Josh
It's interesting that you say this problem started to show itself after you changed the intake gasket. It may be that you had an internal vacuum leak with your old gaskets that helped reduce your crankcase pressure and now that you have replaced the gaskets, you are back to relying only on the PCV system.
So following up on Bruce's question, what do you have for a PCV system? I have seen where aftermarket PCV valves/vent caps do not allow sufficient crankcase ventilation.
If you can isolate a specific leak, you may be able to test to see if the PCV valve and vent cap are the issue. The leak will probably be close to non existent when idling or even revving up the engine with no load. But go out and drive it and give it a few wide open throttle runs where blow-by is the worst and the leak should be obvious. Using this test method, you can experiment with different PCV's and vent caps.
Just as a reference, I use the Motorcraft M-6766-B302 vent cap and EV 68 OK31 PCV and it seems to work fine
Craig
