Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 08-31-2006, 10:13 PM
panteraman's Avatar
Cobra Make, Engine: Pantera....sorry
Default 514 (460) oil usage
hi all, I have about 5000 on my 514 crate motor and just took a trip to Monterey.....490 miles each way....things ran great on the way up...overcast about 70 degrees.....no oil usage. On the way back I hooked up w/a few guys that ran pretty hard.....about 3600 tach (115-120mph?) down the 33 w/of the 5 n of Bakersfield.....outside temp appx. 105...car temp ran just under 200....but stopped for gas and dipstick was dry! took 4 quarts to top it off. thank goodness for 10 qt oil pan.....car runs a little hotter now but still stays just under 200. Do you think I did any damage? just break-? I know this is a bracket racing engine but c'mon....3600 rpm shouldn't push it that much....should it? Any advice would be most welcome as I don't want to run the car much until I'm comfortable......running Castrol Syntech right now for what that's worth. You're talkin to a rookie here but I want to learn so thx in advance for your opinions........
Old 08-31-2006, 11:40 PM
Cobra Make, Engine: Johnex EQ
Default Oil usage
I would check for leaks. I have a built 460/ 800 hp and a small leak can pump out a lot of oil. Goog Luck, Ed
Ed
Johnex EQ 514
Old 09-01-2006, 02:18 AM
wtm442's Avatar
Beam Me Up Scottie
Check the spark plugs. If they are all a nice tan color and not wet, you have a leak.
Warren
Old 09-01-2006, 09:37 PM
panteraman's Avatar
tx for the tips guys....I know what I'm gonna be doing tomorrow now
