Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 02-03-2007, 02:59 PM
jrjmac1's Avatar
Default 429 harmonic balancer?
I have a 1968 429 that doesn't have a harmonic balancer on the crankshaft. Is this because it is internally balanced? or is it missing?
If I can put one on, do I use a neutral one? I need to check if there is a keyway and pulley alignment problems involved. I need the balancer for timing as well.
Any help is appreciated.
Old 02-03-2007, 03:20 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Any 429/460 harmonic damper should work. In '79 they went to an external balance, but there is a "hatchet" behind the damper and a weight on the flywheel. A harmonic balancer is not a weighted object always, their primary purpose is vibration "damping" as the name implies.On the 429/460 it isn't, on some Fords it is but not the 385 series.
WDZ
Old 02-04-2007, 07:17 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Damper
I've seen 385 series fords without dampers, but unless you have a reason to do so (like driving high loads off the crank, like a giant roots blower or something), I'd run one.
No matter how good the balance job, the crank will still be subject to harmonic vibration. The damper is a mass/spring system that absorbs the vibration and makes life easier on the internals, bearings, etc. It's worthwhile.
B
Old 02-04-2007, 10:40 PM
jrjmac1's Avatar
Thanks for the response...I'm trying to find a balancer that will work with a March serpentine pulley system, alignment etc.
Thanks again,
jrjmac1
