Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree2Likes
Old 08-30-2007, 11:36 AM
ItBites's Avatar
KCs 514 package isn't comparable due to the cast crank and I also think shipping is charged on top of the price advertised, and I do not think you get a 2 yr warranty. I have also heard many horror stories about 514s eating cams and lifters... Certainly no comparison to the reliability of any BBC (bullet-proof)oiling system.
However, the new generation of ford heads really brings the power of the fords right into chevy territory!
E. Wood
ItBites
Old 08-30-2007, 12:26 PM
Tom Wells's Avatar
IB,
I'm thrilled to hear that your
soon to be 540 cid Chevy
is
bullet-proof
Must be quite thrilling
Old 08-30-2007, 01:02 PM
vettestr's Avatar
For pretty-much ready to fire up cast iron engines we generally use 575 and 685 pound figures for weight. So a big block is only 110 pounds more and aluminum heads drop a quick 42 pounds over cast iron heads. That is 42 pounds of a 5248% differential on a 2500 pound car. If your girlfriend gained 42 pounds you would know it pretty quick but on a street car so what.
If you use 1 HP per cubic inch just for sake of argument (1 HP per inch is a fair benchmark I think for custom engines and not that far off for a performance crate engine) Depending on money spent a ratio of 2 to 1 is sure possible. I had a $$ Shafiroff 540 in my own car, aluminum, injected and all the goodies, it gets crazy quick. The weight difference between a small block and a big block gets lost in the math of horsepower per pound VERY QUICKLY.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 08-30-2007, 01:28 PM
ItBites's Avatar
Tom Wells,
Thanks; I'm thrilled that you're thrilled to hear about it. Engine will go in this weekend if all goes well. Of course, I know you are sincere. Thrilling for the thrill of it...
E. Wood
ItBites
Old 08-30-2007, 02:18 PM
Originally Posted by TerrysSPF
It would be interesting to see the weight difference between the Shafiroff 540 BBC and KC's 514 BBF.
Anybody have a clue?
Most BBF's I ship are 670-700lbs including the crate, which is made of a pallet, six feet of 2x10, two 4x8's of plywood, and about sixteen feet of 2x2. The crate/pallet is probably at least fifty pounds, so that leaves you at 620-650 for a fully dressed big block Ford. This range includes combos with cast cranks, iron heads, alum intake, as well as combos with forged crank, alum heads. No clue on the weight of a BBC.
Originally Posted by Jerry Clayton
Cast crank vs steel crank is a biggie---all the ford packages are cast cranks---all the Chev packages are forged steel--
For the record, there are forged BBF cranks available. Cast BBF cranks (and stock 2-bolt blocks) have been proven to handle 700+HP without any issues. The new forged offerings are being run in 1500HP applications without breakage.
If you're talking a BBF crate engine from Ford, you should probably know that Ford has discontinued it's current big block crate offerings. Rumor has it, they're designing a new block to be used as part of a new big block crate engine. No offical release date for the new crate from Ford. Could be 2008, could be 2010, could be never. If/when the new engine comes from them, you can be sure it's going to be much more expensive than before.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
Old 08-30-2007, 02:26 PM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
what is the weight savings on an aluminum 427 block and a cast iron one?
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 08-30-2007, 02:52 PM
RodKnock's Avatar
It seems that the Edelbrock aluminum head is the choice of many Cobra owners for their BBF builds, and granted I don't have the flow rate numbers in front of me, but the BBC has the advantage of some very trick aluminum heads from manufacturers such as Brodix, Air Flow Research, Trick Flow, Dart, World, etc. in addition to the Edelbrock head. I have AFR 315cc heads on my 540 and they flow great, but AFR also has 335cc and 357cc heads. Brodix has several lines for the BBC. I think (and hope) that these same manufacturers will begin to make some great heads for the BBF in the near future as well.
Old 08-30-2007, 03:50 PM
ItBites's Avatar
Rodknock,
Dart also has the new 18 degree offering that uses normal intake and valvetrain components. Sort of mid-way between the normal 23 degree Dart heads and the Big Chief valve geometry. Should be good for +50hp in a direct swap...
E. Wood
ItBites
Old 08-30-2007, 04:06 PM
CHANMADD's Avatar
I run a SBC 400, bored 0.030 (406) and it runs great. As said the distributor is difficult to get out ,but I have found that if I take the intake ,manifold and distributor out together its really easy.
Old 08-30-2007, 06:00 PM
RodKnock's Avatar
Thanks E. Wood, I will look into the Dart offerings.
Old 08-31-2007, 12:27 AM
Cobra Make, Engine: Cobray, 468 chevy oval port heads 10.5 to 1 Richmond 5 speed
I was also considering running a 406 chevy, I found a really good deal on one from an engine builder from e-bay. He was going to build be an aluminum headed (Dart pro 1 platnum) 406 with a steel crank and hyper pistons from speed pro for $2900. Shipping was an extra 275. What kind of cooling system are you running Chanmadd? I've heard the cooling problems with the 400 sbc is really a myth. They just heat up faster when you have a cooling porblem.
Old 08-31-2007, 06:40 PM
WV66AC's Avatar
Cobra Make, Engine: Late 70s Allied Industries?? 454 BBC; alum copo heads and intake THM 400 12 bolt posi ++ 06 CL 55 AMG
74 454 block, 68 alum heads, it starts easy after storage and runs. Nuff said.
