Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 11-02-2007, 10:42 AM
BDHE's Avatar
Cobra Make, Engine: Superformance, PE 514
Default Popping When Cold
Greetings;
I'm running a Performane Engineering built 514 with a Demon 850 racing carburator (no choke). When she's cold, I get some popping out of the right bank of cylinders from cold start to warmup. When the car has warmed up, it goes away completely.
I'm wondering if this is normal behavior, or if it's something to be concerned about.
Bryon
Old 11-02-2007, 11:10 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
Checked the header bolts? One could be a little loose allowing a leak when cold but as things heat up they tighten up.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 11-02-2007, 12:23 PM
Good call Doug. I betcha that is it.
Old 11-02-2007, 01:06 PM
Rick Parker's Avatar
May have to do with the fuel falling out of suspension as the charge hits the bottom of the manifold before there is ANY heat, whether there is a heat crossover or not.
Old 11-02-2007, 04:38 PM
Rick is right.....it's just because it's cold and it doesn't have a choke. When it's noticeably colder outside, it will do it.
Old 11-03-2007, 03:13 PM
BDHE's Avatar
Rick/Blykins;
This just became noticable when the ambient air temperature started going down.
The first thing I thought of was loose header bolts, but they're all tight. The bolts connecting the headers to the side pipes accepted a small amount of torque, but not enough to have allowed them to leak.
Thanks for your opinions.
Bryon
Old 11-12-2007, 02:39 PM
BDHE's Avatar
Greetings;
I've noticed that if I warm the car at about 2000 rpm for a minute before leaving the driveway, the popping I had noticed previously was gone.
This must be a quirk associated with running a Demon 850 racing carb (no choke). When it's warm though, it's HOT!!
Bryon
