Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
February 2026
Old 02-11-2008, 04:56 PM
Silverback51's Avatar
Question Header Bolts
Has anyone used Percy's locking header bolts?
Percy's 20004 - Percy's Split-Lock Header Bolts - JEGS
Old 02-11-2008, 06:06 PM
Tom Wells's Avatar
Silverback51,
I tried them on my aluminum SCJ heads. I almost ruined one bolt hole.
Two things happened that I didn't like:
1) More than one of the setscrews fell out after the car ran through several heat/cool cycles.
2) The bolt itself resembles a tap; in trying to remove one of them to go back to the Stage 8 bolts, the bolt tried to tap one of the holes oversize. It apparently didn't collapse to its original shape when I took the setscrew out. Yikes!
Having said that, they may be OK for iron heads. Definitely not recommended for aluminum.
I told them this at PRI year before last and thought they were permanently withdrawn from the market. Maybe not.
I now use the Stage 8 bolts. They are a hassle to fit, but they seem to be compatible with the aluminum heads.
Hope this helps,
Tom
Old 02-11-2008, 07:43 PM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
Sorry for this slight hijack...
Tom,
I bought of Stage 8 bolts and am planning to install them when my headers come back from ceramic coating later this week. Do you have any installation tips?
Thanks,
Chuck
Old 02-12-2008, 06:15 AM
Tom Wells's Avatar
Chuck,
It's been more than two weeks since I put mine in
I recall having to take my time and study each little retainer individually. Some seemed to fit "as-is" and others required a bit of grinding to get them on snugly. If they weren't ground down a little, some of them would not go on at all. This is part of what I meant by "hassle". The other part is getting the C-clips on - I had to use the Braille method and some real contortions
One other thing I did was to mark each one so if I ever had to take them off, I could get them back in the same spot; this means marking them so I knew which side faced the head. I did do this once and (mostly) got them back on satisfactorily.
The good news is they were harmless to the heads, and I could R&R the headers if I had to. A real PITA.
All in all they were worth it because header leaks are few and far between now, where they used to happen every other week especially if I abused the car a bit by taking it to the track.
I tried good quality header bolts early on, and they just wouldn't stay.
Tom
Old 02-12-2008, 09:48 AM
Thank you for the input.
Old 02-12-2008, 11:53 AM
rdorman's Avatar
Renegade Nuns on Wheels
Try safety wire after a retorque.
OhioCobraClub.com
LondonCobraShow.com
Old 02-12-2008, 12:14 PM
undy's Avatar
Go with the Stage 8s. I had the "split bolt" ones in some aluminum heads I had on a 383 SBC. If they weren't loosening up, then they were galling the threads. If there were no expansion, contraction and/or vibration they'd work fine..
Too many toys?? never!
Old 02-12-2008, 04:47 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
I agree with rdorman. ARP makes a nice set of pre-drilled stainless header bolts ala NASCAR.
Bill Stradtner
