Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 11-16-2007, 02:46 PM
Default Toploaders and 460
I know you can use a Toploader with a 460BB, but is there a particular one I should be looking for. Most of the cheap ones I see selling on Ebay are from Mustangs and Cougars from the late '60s and early '70s. I know those cars didn't have big blocks, but will the same Toploader for them work for a 460 from the '70s? Anything else I need to know?
I would like to find a used (cheap) TKO 600, but I can't find any out there! I want to go as cheap as possible, because I'm still saving for my Cobra.
Thanks,
Joe
Old 11-16-2007, 02:54 PM
xlr8or's Avatar
If you want the scoop on Top Loaders call David Key Top Loaders.
Old 11-16-2007, 03:38 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Basicly there are 2 top loaders, a BB and SB kind( this doesn't include the close or wide ratios or tailshafts,just basic construction). The BB has a bigger input shaft. Many Mustangs of the years you mentioned came with Big Blocks,so the trans may have been the correct type.BBs came in Mustangs and Cougars since 1968, they ran through the early 70s.
WDZ
Old 11-18-2007, 06:18 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
You want whats called a big input / big output with a short "nascar" tail. But, like xlr8or said, call David Kee and talk to him, he's the man. Then tell him your rear end ratio so together you can decide weither you want a close or wide ratio trans, I have a close ratio with a 3:70 rear and like it just fine.
" It ain't no big deal"
Old 11-19-2007, 10:49 AM
Thanks for the input guys.
Joe
Old 05-09-2008, 03:37 AM
They were called "bullnose toploaders with the big shaft", getting harder to find and not overly cheap either.
Andy.
All torque, no traction!
Anything is possible (if you can justify throwing bucket loads of money at it!).
Old 05-09-2008, 06:24 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
All 427,428 and 429's came with close ratio (2.32 1st gear) 31 spline transmissions. If you want a wide ratio (2.78 1st gear) 31 spline trans they put them in 71-73 torinos but they have the smaller input shaft, which can be changed.
Cobrarich
