Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 11-30-2008, 08:44 PM
Cobra Make, Engine: Midstates, Ford 460
Default Cam change without pulling engine?
I've got a midstates with a 460. Should I be able to change the cam without pulling the engine out? Space is VERY tight in there... I will also need to change the valve springs... Thoughts?
Old 11-30-2008, 08:55 PM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
well maybe measure how long a cam is and then measure in front of the engine. that should tell you if you have enough room. and springs, if you're going with a bigger cam than it might be a good idea to get matching cam and springs.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
Old 12-01-2008, 07:58 PM
If you pull the drive shaft, and remove the trans, crossmember, loosen the moter mounts, then drop the tail end of the tranny down, and point the front of the engine upwardes you should be able to do it, let me know.
