Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-27-2009, 08:00 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Question Header size vs torque make a difference?
Reviewing my dyno report on my BB 533 stroker Ford engine I find that it was run with 1.75" OD headers and measuring my current ones that came with my kit, they're 2.00" OD. I've heard or read somewhere that a smaller headers would result in higher torque - would a change as above result in a noticeable difference? I know there are many ways to optimize low end torque, but I'm wondering, all other things being equal, if the header diameter is a significant contributing factor or not.
Thanks!
Dirk
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
Old 04-27-2009, 10:35 PM
kitcarbp's Avatar
Default Primary Pipe Diameters
Dirk, In general yes, the diameter of the primary pipes will affect peak torque value and what rpm that peak torque occurs at. Exhaust gas velocity increases as diameter decreases, but flow rate(cfm) decreases as dia decreases. For street driven rpms most advise 1.75-1.875 inch pipes is fine for big cube motors. There are software packages the pros use to simulate best header designs when it comes to racing.
Here is the owner of Sanderson Headers take on affects with data for a small block engine. The 533 cubic inch monster has plenty of torque in any case whether 1.75 or 2.0 inch primarys are used. There are other ref out there as well
http://www.sandersonheaders.com/tech_get_technical.php
Old 04-28-2009, 05:49 AM
Cobra Make, Engine: jbl
i'm thinkng the 1.75 would bee too small, 2" would be more appropriate and those stovepipes look intimidating.
Old 04-28-2009, 07:09 AM
CobraEd's Avatar
Everyone knows that the diameter and length of the primary pipes affects the amout of torque and where peak torque occurs. But I can't remember if the numbers are significant. It seems to me that the differences are small.
________
________
Old 04-28-2009, 07:50 AM
2.00" would be the minimum for your application in my opinion.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
Old 08-26-2009, 03:45 AM
mdross1's Avatar
With all those cubes at hand you would not feel the difference.My 460 headers were built at Tubular Automotive in Mass.They are racing headers 2" pri to 3 1/2" col.This thing hits hard right off idle,with a scaled suspension.
Old 08-26-2009, 08:33 AM
Jerry Clayton's Avatar
the differences might be small between the 1.75 and 2 headers on an engine that size---but if you would actually put a header on of the size the engine needed, you would see a more pronounced differance-----On that engine I would at least run a 2.25 and preferably a 2.375 header
Old 11-16-2009, 06:43 AM
mdross1's Avatar
When my headers were being sized up for the 460,2" was the biggest pipe they could fit around everything.
