Old 01-13-2004, 09:40 AM
misfit41 misfit41 is offline
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
thanks again for the post,I am trying to keep this on a budget,but I was thinking for 3500 ,that should cover heads,cam,valve train and pistons,I have a used unilite distributer I may use,as well as a ford duraspark{they say thse still work great with msd}
I had not even thought of using the old heads because of weight,and I am not sure if they will port match my med riser intake,I do have an old 427 eldebrock port matched to heads though,I may reconsider,I can always buy new heads later on.
I like the idea of the 4.25 crank and bbc rods,does any one know how much prep work is required to use this set up ? I am thinking with a 6500-6800 rev limit,a cast crank would be fine,any piston reccomendations ?
thanks again,,Tim
Tk
"this whole Adult thing just isnt working for me "
