Old 01-14-2004, 02:16 PM
Cracker Cracker is offline
Chuck,
I too have a SO and there is no special instructions on removal other than be careful but that goes for any engine. Intake bolts torque to 35 lbs. are tightened in a cris/cross pattern. I put a little permatex on each corner bolt just as a precaution but I don't believe they enter a water jacket. As far as rocker arm removal simply take the four (six) including end stands in your case and lift off. Valve lash is going to have to be reset regardless of disassembly procedure. I have the same Comp system on my 428 and it is sufficient. Make sure you do a final cleaning of the entire rocker shaft assembly prior to installation. Feel free to call me if you have any further questions at 770-664-7670 as I live down the road from you in Alpharetta a few miles from the other Kirkham (TC's). Best wishes!
