Old 01-14-2004, 07:58 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Chuck,
I would also add ....when you remove and replace your rocker assy. run the bolts out ,and back in one turn each bolt at a time....so as to avoid flexing or even breaking your rocker shaft due to uneven pressure imparted by the valve springs.
I also , very carefully put a small bead of hi-temp sealant around the waterports before reassembly.
And .....DRAIN your radiator..! Aquart of coolant in your crank case can really spoil your fun.....
KK
Foolish consistancy is the hobgoblin of tiny minds
